windsor sr, crane, motorsport, msd, comp, ect
BD351RS
Connersville, IN
convertable mounts (used) $25.00
750 hp series holley carb (literally only 3 passes, no street miles) $350
Motorsport intake 351w (same as Victor) (drilled and tapped for a fogger system) $150
MSD Distributor 351w (used) $125
Windsor Sr. heads 2.05/1.60 (used very little) w/comp springs for a HR, Solid Flat, or Hyd Flat $700
ARP head bolts 351 (missing one short one) $30
Harland Sharp 1.6 roller rockers 3/8 stud (used) $125
Comp Push rods (new) for 351w $75.00
Jegs Alum Valve Covers (new) $50
Ford Racing Timing Set (new) $50
Crane Cam and Lifters (solid flat, works 3200-6800 rpms) (new) $125
Ford Racing Oil Pan (351 Fox Swap) (new) $150
4 CYL T5, I have not driven this tranny, previous owner assures me it is in good condition.... With that being said, if someone buys and it is not, i will return your money... If u wish to have it inspected first, you can give me a deposit (refundable) and have it inspected... Trans was behind a mild 306 with no problems...(i was told) $200 obo
Brand new King Cobra Clutch Kit, clutch, pp, throwout bearing, pilot bearing. This setup is rated upto 400hp $169.99 retail, $120 firm
Brand new 28oz Fidanza SFI Billet steel flywheel, (weight is removeable if u have a 0 balanced motor or put on a 50oz weight for newer 351 and 302) $179.99 retail $130 firm
Used Steeda clutch quadrant, firewall adj, and clutch cable $50 firm
Used Hurst shifter $80.00 firm
text or call 765-541-0577 thanks troy
Everything is priced to sell, no need to try and negotiate unless its marked obo, if you dont like the prices then look up new prices and then look back to mine. I'm sick of lowballing $%#* who want something for nothing people... Dont try to build it if u cant afford it!!!!! I'm really a nice guy:)!!!
