Wipers
There is said to be a black box below the dash that controls this. I have a part number at home(at work now) but ford doesn't make it and they are like 90 bucks from 5.0 and mustangs unlimited (hate spending that much if it "might" only fix the problem)
with just full speed working, 99% it's the Interval Governor.
check power on W wire at wiper motor wiper switch LOW or INT. if no power, check for power at Governor on BR/W wire Pin9 with key ON and wiper swt in LOW. and power at DG wire Pin10 when set to interval. if you have power then governer is bad.
Just in case that one doesn't work, on the Tempo and Topaz you have to remove a metal plate ( I think it was under the steering column) to get to the module. A couple of the bolts are hidden so you kind of have to dig around a little.
It's been awhile so I'm not exactly sure. It's close to the same area, but I think is was a little higher up. I remember that I couldn't get to the part without removing the panel. Two of the bolts were hidden by plastic trim caps on the instrument cluster.
