Wiring Diagram for Fuse #8 94 GT Vert
velocity
48
Colorado
My Fuse #8 keeps blowing. It controls the door chime, clock, speedo, odometer, etc. Does anyone have a wiring diagram for fuse #8 and a diagram to show were everything is located so I don't have to hunt everthing down?
Any one have any suggestions on how to approach fixing this??
Thanks in advance
I think the back of a Haynes manual will have something.
Does the fuse blow immediately?
How I treat issues like that:
I disconnect every item on that circuit. Then I start plugging them back in, one at a time. When I get to where one is plugged in and it immediately blows the fuse, I know that's the bad one. Then trace the wires on that bad circuit.
This is where knowing if the fuse blows immediately helps. If not, you can actuate each item one at a time until it blows. This can save having to disconnect everything.
If a mod sees this thread, it would be better suited and get more views (perhaps) in 5N95 Tech.
Good luck.
A higher-up on the website has to move it. The mod would have taken this thread and moved it from Talk to Tech. All you can do is start a new thread in Tech. A mod will merge the two threads however.
Good luck.
