wiring diagram
Hey fellas, i found a OEM after market ford alarm in my garage that my dads stored away for the longest time.. brand new straight from 96 :D all the stuffs there along with the diagram but the wiring colors of a 95 stang are diff than mine.. does anyway have a diagram that can tell me these :
to starter from the ignition switch
parking lamps
mainly just a big diagram would work to.. i have a couple others that i have to check.. but till then can anyone help me on these?
Autozone's website has tons of wiring diagrams under the Repair Info link.
On a side note, you said it's an OEM Aftermarket alarm.. isn't OEM and Aftermarket 2 different things? One meaning Original Equipment, the other meaning NOT original equipment? :)
On my 88, the parking light wire was brown and i grabbed it under the dash, between the steering column and kick panel. There are a few brownies, so probe them with your meter.
If you mean the crank wire (for a starter kill), it is white/pink IIRC. You can grab it at the ignition column, clutch safety switch, solenoid, etc.
Good luck.
alright thank ya much guys.. i ment that its a after market type deal that ford makes.. you can order the kit as a custom deal.. you could not get it ordered on a car in 94-95 factory. Its a different kit, includes a valet switch, kill switch and such. It will work good when its hooked up right.
And jrichker was just the guy i was looking for lol i knew you'd come through with diagrams
