Wiring help for 1 wire alt and Accell distributor
  • Thread starter Thread starter whatagearhead
  • Start date Start date Jul 21, 2007
whatagearhead
60
Chandler, AZ
Jul 21, 2007
  • Jul 21, 2007
We've decided to move to an Accell "ready to run" 52000 series distributor and a one wire 140 amp powermaster alternator in my son's '70 coupe. I also picked up a new (correct) coil. The distributor has the appropriate steel gear for the '89 5.0 HO motor we're using with the roller cam.
Can anyone provide a wiring diagram that shows how I should hook everything up? All the stock wiring under the hood was for a 6 banger/3 spd. w/ old style alternator, ballast resistor, voltage regulator, etc...
I assume the old voltage regulator goes away, I know I need to eliminate the ballast resistor. I'm not sure what to do with some of the old wiring under the hood and eventually I may build a new harness. For now I want to get it running with what is there if possible. The '89 starter only has 1 lug on it so I assume we'll still have the fender mounted remote solenoid.
I also need to figure out what to do with the old wiring that went to the manual trans. We have moved to a T5.
Thanks in advance, Tom
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 21, 2007
  • Jul 21, 2007
I can't help with the distributor or alternator. I've only put 3G alternators in, now the 1 wire setups.
As far as the starter, ya, it just goes in like the original did off the starter motor relay. The T5 should have some terminals on it which close a circuit in it for the reverse lights. I think the old manual shifters wired off a switch in the shifter mechanism instead off off the trans. Since you have no neutral safety to worry about, you should be able to wire the reverse lights from the old shifter to the terminals on the T5.
whatagearhead
60
Chandler, AZ
Jul 21, 2007
  • Jul 21, 2007
Thanks Jeff
BTW - As you know I tried to go cheap (with the duraspark) but at the end of the day this just made more sense
whatagearhead
60
Chandler, AZ
Jul 21, 2007
  • Jul 21, 2007
So at this point I have it wired as follows - am I missing anything?:
Solenoid (rear large terminal) - hooked to starter terminal
Solenoid (front large terminal) - 3 wires including:
1) a connection for Battery (+)
2) Alternator charge wire (1 wire Powermaster alternator)
3) black wire from original wiring harness (I assume going to fuse block)
Solenoid also has 2 smaller terminals - which are hooked up as follows:
1) brown stock wiring harness wire on small post towards front
2) red/blue stock wiring harness wire on small post towards rear
The Accell distributor is wired as directed (3 wires)
Red - took this from where the red wire was attached to the ballast resister coming out of firewall (ballast resister eliminated per instructions).
Black (engine ground)
Brown to (-) side of coil
I disconnected and removed all the wiring for the external voltage regulator, which leaves an original light blue connector with 2 wires on it connected to nothing. These wires are:
1) black
2) green
whatagearhead
60
Chandler, AZ
Jul 22, 2007
  • Jul 22, 2007
Anybody?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 22, 2007
  • Jul 22, 2007
1) black
2) green
Thats how 1 wires are supposed to hook up as far as I know.
As far as the I and S terminals on the starter motor relay, if you have them reversed, the car will crank in the run possition, no major harm there as long as the oil pump is primed. Just switch the terminals if it is wrong but I think you got it right.
You no longer need the voltage regulator hooked up but I'm not sure about what those other wires are. Post a pic ?
whatagearhead
60
Chandler, AZ
Jul 22, 2007
  • Jul 22, 2007
Jeff - thanks again for jumping in
here are a couple of pics - you can see the hookups on the solenoid and the "extra" connector I have now. I did this all from memory/guestimate and more eyes looking at it are better
  • dan50
  • Jul 18, 2026
dan50
1991 3g alternator not charging
  • BigShowJoe
  • May 12, 2024
3K
Fox 5.0 Mustang Tech Mar 30, 2025
Chuckster101
C
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
