  • 1994 - 1995 Specific Tech
Wiring Question: multiplying the cigarette lighter plug
  • Thread starter Thread starter GRGT1994
  • Start date Start date May 30, 2005
GRGT1994
1,034
  • May 30, 2005
I want to set up an extra 2 accessory plugs (cigarette lighter plugs). Does anyone know how this would work?
What I really want to do is put the power in the arm rest box. So I was thinking about wiring off the existing one in front of the shifter. But I don't know whether it should be wired in serial or parallel. I am guessing parallel. Anyone know?
If not, are there kits to do this?
HISSIN50
34
129
May 30, 2005
  • May 30, 2005
you can wire the new ones up separately (sourcing power from another circuit altogether) or use the existing circuit. tap power from the existing outlet and run it to the new outlets (be sure to install an inline fuse).
depending upon what you want to power, the vert harness is right under the console - you could use that as key-on power for your new outlets. Just be careful with your wiring and use fuses. I would want outlets with covers so that change cant be accidentally dropped in the outlets (which often will short out the circuit).
good luck.
M
1991 GT cigarette lighter/port not working (horn is working)
  • MartinM
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
MartinM
M
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
