Wiring questions + Fuel issues.
mavmavv
185
Just bought a steal of a LX (600 dollar runner) and I want to make it into my daily. The car I bought runs and all, but it definitely needs some work.
Ive replaced the TFI + PIP in the distributor. Replaced the Coolant Temp Sensor. Have a pretty good spark at coil and at the plug. The car will start after its been sitting for 30 mins or so and if I fiddle with the timing I can sometimes calm it down and get it to idle. I can drive it, but its pig rich and bucks when im off throttle cruising (Automatic). Most times I have to let it sit a bit before it will fire up again. I can crank it, but no start, even with the foot to the floor.
I want to pull the codes, but I have some wiring off in the interior. I jump the 2 nodes together and I get no blinking, just a solid light. Can someone give me a heads up on where these wires should be?
http://www.easyscreens.info/?v=1366
http://www.easyscreens.info/?v=1367
Anyone have any other ideas? I have fuel in the rail, the pump is priming with ignition, its just so damned rich. Im almost positive I need O2s, but I want to read the codes before I jump in any deeper.
Great forum btw! Ive found so much amazing information without ever needing to make a post.
The wires you show probably do not connect to the computer. When posting wiring problems, be sure to post locations and color codes that include the color of the tracer stripe.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Thanks for the post, but im bridging those terminals together with a safety pin or wire and im still only getting a Solid CEL. With the Test light im also only getting a solid light. I can trick the fuel pump into running, so maybe that ground is getting screwed up somewhere.
Guess I should check the wiring. Is there any other place I can tap into ground to get the CEL codes?
No info about your car's model year, EFI or carb, no mods listed. Makes it hard to troubleshoot when we don't know what you have.
Therefore, no clue as to which wiring diagram you need. The wiring changed several times between 79 & 95.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
There are two test paths for cars with computers that won't go into diagnostic mode. They are broken out by model year due to different wire color codes being used on different year model cars. The year of your car wasn't posted or I missed it. Post the year of your car and any other mods in your sig and I will post the correct tech note for your car.
Ok, so I did some work today, checked the resistance through the wires and its through the roof. Its obvious the black/white has a bad ground or something wrong somewhere. I can reset the CEL, but not read the codes. I have the car pretty much drivable, but all the sensors on the CEL line are out, so Im running pretty badly, black smoke out the pipes when revving, pinging very badly anywhere over 1/3 throttle.
I need to know where these wires ground. I have marked them on the image. For the life of me, I cant find the other end for the neutral gear switch.
http://www.easyscreens.info/index.php?v=1385&fullsize=1
Thanks!
[Computer will not go into diagnostic mode on 86-90 model 5.0 Mustangs
How it is supposed to work:
The black/white wire (pin 46) is signal ground for the computer. It provides a dedicated
ground for the EGR, Baro, ACT, ECT, & TPS sensors as well as the ground to put the
computer into self test mode. If this ground is bad, none of the sensors mentioned will work
properly. That will severely affect the car's performance. You will have hard starting, low power
and drivability problems.
Since it is a dedicated ground, it passes through the computer on its
way to the computer main power ground that terminates at the battery pigtail ground. It should
read less than 1.5 ohms when measured from anyplace on the engine harness with the battery
pigtail ground as the other reference point for the ohmmeter probe.
What sometimes happens is that the test connector black/white wire gets jumpered to power
which either burns up the wiring or burns the trace off the pc board inside the computer.
That trace connects pins 46 to pins 40 & 60. Only an experienced electronics technician can open
the computer up & repair the trace if it burns up and creates an open circuit.
The STI (Self Test Input ) is jumpered to ground to put the computer into test mode. Jumpering
it to power can produce unknown results, including damage to the computer. The ohm test
simply verifies that there are no breaks in the wiring between the test connector and the computer input.
How to test the wiring :
With the power off, measure the resistance between the computer test ground
(black/white wire) on the self test connector and battery ground. You should see less than
1.5 ohms.
attachment.php
If that check fails, remove the passenger side kick panel and disconnect the computer
connector. There is a 10 MM bolt that holds it in place. Measure the resistance between
the black/white wire and pin 46 on the computer wiring connector: it should be less than
1.5 ohms. More that 1.5 ohms is a wiring problem. If it reads 1.5 ohms or less, then the
computer is suspect. On the computer, measure the resistance between pin 46 and pins
40 & 60: it should be less than 1.5 ohms. More that that and the computer’s internal
ground has failed, and the computer needs to be replaced.
If the first ground check was good, there are other wires to check. Measure the
resistance between the STI computer self test connector (red/white wire) and pin 48 on
the computer main connector: it should be less than 1.5 ohms. More that 1.5 ohms is a
wiring problem
The following is a view from the computer side of the computer wiring connector.
Check out the diagram and notice all the places the black/white wire goes. Almost every
sensor on the engine except the MAF is connected to it.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
Thanks a ton. I checked the resistance in the black/white at the computer harness and the self test light and its a very low reading. Very normal, no problems in the wiring. The ECU was giving me bad readings, im gonna go ahead and order a new one.
From the looks of the wiring on this car, some dummy didnt know what he was doing and fried the computer. Oh well, im keeping my budget under 1000 bucks to get this thing running and it looks like ill be well under. Thanks again!
