Hi,I'm having problems witht the car not wanting to start after it has been ran for awhile.I moved the fuel/air sensor that was located on the cold air intake and placed it into cylinder 5 as to what Pro M said to do.I will list my mods that I have done so far. I need some sort of idea of what direction to go.
Edelbrock Victor 5.0
AFR 185 heads
Lunati Cam 232 duration 550in/564exhaust
DSS Flat top Pistions
30lbs injectors
80mm Pro M mass air\
Crane Cams Hi6 w/ LX92
75mm Throttle body off of Fox body 93
Mac 1'3/4'' equal length shorties
Mac Power Chamber
G Force Transmission
I havn't changed to factory computer yet, I have the check engine light coming on also.I tried to turn the fuel pressure down to 35lbs but the car ran really crappy, I turned it back up and its running rich.I drove the car today and when I stepped on it at WOT it ran the rpms up then acted like it was cutting out and fell on its face. I changed out the plugs again and put back the sensor on to the cold air induction today I let it run for about 5 minutes and check the plugs after I shut it off and they were starting to carbon up. I noticed when I shut the car off that it doesn't hold pressure in the fuel line by watching the gauge that I installed on the fuel rail.I could get the pressure regulator to turn down any past 38lbs. I'm completelly lost .
AFR 185 heads
30lbs injectors
Mac Power Chamber
