work in progress
  • Thread starter Thread starter pnyinprgrs
  • Start date Start date Jan 24, 2006
P
pnyinprgrs
27
  • Jan 24, 2006
bought car as a kind of project and was wondring what order I should do my work in.
Here is a list of what needs done and was wondering if someone could give breakdown of the best process to do the work in and what are some good parts. Work will be getting done as the funds provide, and I am a newbie so any advice would be more than appreciated.
Here goes (Rear brakes, E-Brake cables, Fuel injection purge, Rack & pinion, Valve-oiland Timing cover gaskets, Frt stuts,Frt springs, Rear shocks, Frt wheel bearings repacked, Sway-bar links, Trans output-shaft seal and molded heater hose.)
Sorry for the really long post just wondering if anyone can help me out and point me in the right direction.
9
93-331-29psi
157
NE North Carolina
Jan 24, 2006
  • Jan 24, 2006
Is the car driven right now or is it a project that isn't driven?
P
pnyinprgrs
27
  • Jan 24, 2006
right now due to bald tires and the ice it is not being driven but probably will be driven come spring.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 24, 2006
  • Jan 24, 2006
How much is done to the car already? If it's stock and you are looking for a place to start, you can choose to follow this list:
First mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered for a stiff chasis
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices
3) Full Exhuast (headers, hi-flo cats, catback +mufflers)
4) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
5) Bumped timing to 12 - 14 degrees (free mod) 10 Degrees is stock.
6) Larger MAF, TB (MAF cars from 1988 california only, 1989-1993)
7) 3G alternator upgrade / electric fan
8) Fix the weak brakes
Optional MODs:
9) Strut tower brace (necessary on Convertibles IMO)
10) Underdrive pullies (they can't be used on S/C motors and cause charging problems)
11) Weight reduction out of the nose of the car
12) Shocks/Struts and lowering springs
13) C/C plates if you lower the car
14) Short throw shifter (if you have a manual transmission)
After those (the basics), it's pretty much up to you. There are plenty of Super Chargers or Heads, Cam and Intake packages to choose from.
Also, don't forget about the basic tune up
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft are prefered
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see first mods item #4
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
Quoting someone "You need a good foundation before building the house"
P
pnyinprgrs
27
  • Jan 24, 2006
right now the car is compltetly stock and had the car at the garage and that was the list of repairs pretty much.
9
93-331-29psi
157
NE North Carolina
Jan 24, 2006
  • Jan 24, 2006
My priorities would be in the following order based on the list you provided. Safety first.
Brakes
wheel bearings
Rack & pinion
Sway-bar links
Frt stuts
Frt springs
Rear shocks
molded heater hose
Then when time to upgrade items do brakes, followed by suspension, then powertrain.
P
pnyinprgrs
27
  • Jan 24, 2006
thanks for the input. if anyone has anymore it would be greatly appreciated.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
Progress Thread 87 T-top slow progress
  • wobbyguy
  • Feb 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 10, 2025
nickyb
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
