Worst gas mileage possible with a stock motor
Apr 16, 2003
153
Maryland
I have a 92 mustang 5 speed with moroso intake, march pullies, bbk headers, bbk o/r H, and mac catback.
I am getting about 180miles to a tank of gas shifting every time below 2500rpm.
I have changed everything on this car including
-plugs
-wires
-cap and rotor
-fuel filter
-pcv valve
-both o2 sensors
-set timing at 14
-seafoam
I just dont get this, it went from about 240 to a tank to 180 suddenly. The car seems to have lost some low end response but is strong on full throttle. Where should I go with this, maybe to the fuel pressure? There is no black smoke. Thanks
1. Pull trouble codes;
2. Pull/check/clean the EGR valve;
3. Check all vacuum lines for any broken, disconnected, or leaking lines;
4. Pull and check IAC sensor (sometimes they get gummed up with gunk);
5. Check/clean all ground cable contact points;
6. Perform weight reduction modification upon accelerator pedal by deleting lead foot. :D
What's the Miles per Gallon?? Miles per tank can vary because of the gas guage. Fill the tank all the way up drive some miles maybe even 180, refill the tank. Divide the miles driven by the gallons required to refill the tank and you will have a pretty good measure of your MPG. For example you fill the tank drive 180 miles refill the tank it takes ten gallons 180 divided by 10 = 18 miles per gallon, which would not be to bad for a 5.0 and city driving
My car currently only has headers, offroad h-pipe, flows dumped and a set of 3.73 gears and I am currently at 220 miles since I filled up last month, I am going to run it till it dies to find out how far it will go:nice: as of right now Im at about 15 miles per gallon, but I'm still going so I will be sure next week when it runs dry.:nice:
Running your tank dry is a good way to kill your fuel pump in short order. :(
-plugs
-wires
-cap and rotor
-fuel filter
-pcv valve
-both o2 sensors
-set timing at 14
-seafoam
You try sensors yet? When my temp gauge didn't work I replaced my temp switch and temp sending unit. When I replaced the latter my gas mileage went from 8 mpg to 15 mpg. When you have a bad temp sending unit your car will run open cycle (start up mode) all the time, so it will run pig rich.
guess I'll chime in. i get 230-250 per tank. highway city combo. 250-280 on a good road trip. My engine is totally stock except for an MSD box. I run 87 grade gas. Anything but Shell or Arco. My car runs like poop on those two. Between being a vert, 6pt roll bar and all the other weight adding goodies I have including my 200lb fatness..I don't know. Maybe it's me. I must be doing something wrong:rlaugh: especially living in So. Cal. I don't get to go to fast very often
Thinking of that, my temp guage never goes up above the second line from the bottom at most?
