worst luck
PeteyAce
346
as some know i had probelms with my gear installion but i was trying to put my covers for my rear drums back on. i was having trouble and was told to turn the adjust with a screw driver. i still didnt get in on yet but when i pumped the brake , brake fluid shot out of my axle, what the hell happened?
LOL...dude, you gotta step back and take a breather. Somethin' just ain't working right for you...
Your brake line must have cracked or come loose or something. To my (limited) knowledge, brake fluid and axles have nothing to do with each other.
You do understand that the "adjust" wheel within the drum brake assembly adjusts (retracts) the brake shoes so you can get the drum back on, right? You keep mentioning the "covers" for the rear drums...
Come on Daggar, you're good for more specifics than just that...lol...Give the guy some details!
And PeteAce...please find out the technical term for the "Covers" you are referring to. Might clear up some things so you can get over the brake issues and get yourself back to those gears!!! Your off on a real "Mod Tangent"...Hey did I just coin a new phrase?
Mod Tangent: A path of vehicle modification unintentionally taken by a modder when issues arise with the initial modification and subsequently lead (backwards) to the ultimate destruction of one or more, totally unrelated, systems leading to further modification and/or repair.
Don't feel bad PeteyAce...we've all been there...
The slave cylinder is the portion of the brake hydraulic system that pushes the brake shoes up against the drum when you press on the peddal. Sending fluid to that cylinder without the drum installed provides no "stop" to keep the cylinder from blowing its own seals out.
yea the covers im refering to are the drums themselves :bang: its really aggravting i really miss driving my car. im gunna look at the drums in a sec. tthanks again guys for the help and thanks daggar for those always helpful diagrams
