worth it??
  • Thread starter Thread starter At1Maverick
  • Start date Start date Feb 24, 2004
At1Maverick
57
Alameda, CA
Feb 24, 2004
  • Feb 24, 2004
I have a chance to get a 351W, it's all in pieces, but the block is already been preped up. now everything comes with it for only $200. does that seem like a good deal, i forgot to write down the casting, but owner says it's off a 70 mustang. the thing is, it's basically an upgrade from the 250 I6 that i have now right?
mfp4073
387
Hells Ditch, FL
Feb 24, 2004
  • Feb 24, 2004
Installing a v8 either a 289 or a 351 is more than just a bolt in swap....there are suspension, drivetrain and other modifications that need to me made. Assuming that the previous owner had not screwed up the 351 it seems like a good deal. Just realize that there is A LOT more to strapping it into your car than is obvious.
69 302/351c
1,147
Walkertown NC, originally Western Mass
Feb 24, 2004
  • Feb 24, 2004
I'm not too sure this is a good deal. You say the block is "prepped". Is this just tanked or has it been rebore? All this pieces are there..are they new or is it just disassembled? Who will build the motor? You? A machine shop?
I, personally, would start with a complete motor, maybe a crate motor, but not a box of used parts. And like mfp4073 said, that's only part of the job.
suspension, driveline, radiator etc.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Feb 24, 2004
  • Feb 24, 2004
Also, if truly original from a 70' it should be a Cleveland not a windsor.
At1Maverick
57
Alameda, CA
Feb 25, 2004
  • Feb 25, 2004
Yeah, I'm aware of those matter and am actually ready for it, I already have a V8 suspension, I have a T-5 hanging around and I have a 4 speed in the car now, a brake upgrade kit is underway too. and I'me pretty sure that it's not messed up
At1Maverick
57
Alameda, CA
Feb 25, 2004
  • Feb 25, 2004
well, it still retains the standard bore all is there from the 4v carb to the fuel pump and all the lines if i want it. heads have been worked on 3 angle valve job, new springs, retainers, seats, etc.
I'm actually going to build the motor myself, I just felt like i went to school and work in the automotive field for a reason, I love working on cars, i want to really say I built it myself.
Autolite closing
  • FastDriver
  • May 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
TOOLOW91
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
