i have a 91 notch with the stage 1 tfs combo track heat. is it worth the time to put a soild roller cam in?? how much more power would i get.?? 4:10's 5spd
Its only worth it if your goals require it. You'll need a new valve train and lifters as well. I personally think your best bet is a good custom hyd roller but it depends what you wanna do. I would say with the hotter lobes of a solid cam, you'd see gains everywhere. But how much, no clue. Cam break in is different too.
Next best thing would be an aggressive custom grind hyd roller with matching valve springs. Are you running stock pistons? If so, you will not be able to go super wild but you will be able to go big enough to run hard.
Hitech motorsports, flowtech induction and buddy rawls all design cams.
