  • 1994 - 1995 Specific Tech
Would a MAF solve this?
  • Thread starter Thread starter flaming70vw
  • Start date Start date Jan 31, 2006
F
flaming70vw
44
  • Jan 31, 2006
I recently put on a CAI (cheap e-bay special) and the engine has a slight ping to it a certain rpms. At full throttle no problem. Looking into a Pro-M, probably a 77 or 80m since there is workd the 75m have problems. There is a 90 degree bend in front of the sensor. Would a new MAF calibrated for CAI fix this? I am running pretty stock, full exhuast, 3.73s, automatic, any input would be greatly appreciated
legalize420
1,541
South Florida
Jan 31, 2006
  • Jan 31, 2006
i would spend the money on something else. buying a new maf wont solve your problem. whats the timing set at?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 31, 2006
  • Jan 31, 2006
I think about two things based on what you said
1. the cai most likely caused you to run a bit leaner. You provide no sig but I'd be willing to bet you are a GT since you talk about a ping issue. Did you have that ping before the cai?
2. if you have plans for more hp, I'd wait on the ProM until you need larger inj's. That way you won't have to pay for a recal.
I would not be able to say for certain a different maf would help your ping issue.
You might clean your maf and check the timing.
Grady
F
flaming70vw
44
  • Jan 31, 2006
Wow you guys are fast thank you so much. The timing is at 14 degrees i run 91 octane, and have a MSD coil. I cleaned the mass air during the cai install. Would it do any good to reset the computer? the pinging only started after the cai was installed
95opal
5 Year Member
Nov 16, 2004
449
20
39
Jan 31, 2006
  • Jan 31, 2006
Off the top of my head i would say to make sure your cia set up is tight, you might have some unmetered air getting in after the maf? you might have to back timeing down or if possible bump your fuel press.. only suggestions of the top. good luck
MLC Stang
210
Atlanta, GA
Feb 1, 2006
  • Feb 1, 2006
Yup... that's two votes for unmetered air getting into your new CAI after the MAF somewhere!
Any unmetered air getting in there will cause you to run lean and ping.
94-302-vert
1,947
NE CT
Feb 2, 2006
  • Feb 2, 2006
CLEAN THE MAF... oil from the new filter probably contaminated it...
  • dan50
  • Jul 18, 2026
dan50
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
Engine BBK Cold Air Kit Rework
  • AeroCoupe
  • Apr 18, 2023
2K
Fox 5.0 Mustang Tech Apr 30, 2023
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
