One of the changes I am thinking about is new gears. Probably 3.55 or so. I would guess that means I also need to do something to the speedometer too. Anyone know what needs to be done? What parts needed, etc?
Jo_885o said:W/ 373's u need a red 21 tooth for a 5 speed.
89MustangGX said:There was a change in Speedo gears in 90(?). The internal gear went from 7 tooth to 8 tooth. This means the correct gear will depend on year of your car (tranny). There's also a 6-tooth gear available if you go really low in gears. Those require disassembly to change.
Oh, and speedo gears are never off by '7 mph' -- the faster the gear rotates, the more it will be off. So if you are off by 7 mph at 30 mph, you may be off by 15+ mph at 60 mph and so on.
