would there be any idle problems with a B303 and an AOD??
FRPP does not recommend a B303 for use with an AOD car and instead recommends the E303 cam. BTW, alphabet cams don't suck, they're actually good little cams, but there are much better and modern ones out there, the TFS stg 1 being one of them.
--Tim
unless you have better heads and intake a b-cam is going to hurt your torque. and torque is what you need to get the aod turning.
best mods on a aod car are converter"edge or pi", gears and shift kit"bauman or trans go"
yeah, I'd do a converter and gears along with a shift kit and a cooler. either that or change the heads and the intake at the same time as the cam or it will be worthless pretty much.
--Tim
I lost power just about everywhere except way up high with my b-303. Go with the TFS cam or anything else.
