would these fit a 69 mustang???
The rear ones will clear but look a little funny. But the front ones wont. I tried some bullets on my 69 Mach 1 and discovered this. The backspacing on newer Mustangs is different than that of the 60's and early 70's. You would need some spacers. Mustangs Unlimited as well as other places carry the spacer kit that you need to make them work.
is the adapter kit from mustangs unlimited all 4 wheels for 300 dollars or just 1 wheel for 300 dollars?
69grande said:
dont u also have to change the studs to make them longer to fit the adapters and the wheels?? What kind of offset is needed on 17x8 rims to make them fit without adapters if theres any?
4.5 to 4.75 is Back Spacing you want for an adaptorless fit.
Check out the chart in the sig.
