Would this be hard to fix?
  • Thread starter Thread starter SaleenSHO
  • Start date Start date Jan 19, 2006
SaleenSHO
41
Findlay, OH
Jan 19, 2006
  • Jan 19, 2006
I have a 1994 Mustang GT that has a leaking rear-main seal. It leaks maybe a quarter-sized drop every couple of days. How hard is this to fix? Can I do it my self? How much $$$ would this repair cost? Thanks in advanvce!
1993SSP
1,194
Ky
Jan 19, 2006
  • Jan 19, 2006
The rear main seal itself is easy. Getting to it is the pain in the arse. It will be a time consuing job, if you have the tools, knowledge and place to do it then go for it. I don't have a clue what a garage would charge
SaleenSHO
41
Findlay, OH
Jan 19, 2006
  • Jan 19, 2006
What all is involved in getting to it?
1993SSP
1,194
Ky
Jan 19, 2006
  • Jan 19, 2006
removing driveshaft, tranny would have to be moved back, flywheel removed, the rear main seal is around the rear part of the crankshaft
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 19, 2006
  • Jan 19, 2006
1993SSP called it. Changing the seal itself takes maybe 5 minutes, but it's the process of pulling the transmission first that makes it a pain. Worse if you have an AOD since they're so heavy, but it can be done in a couple of hours if you're determined enough.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 19, 2006
  • Jan 19, 2006
You need a large garage floor, a friend to help you out and then all of the tools to pull everything listed above. It'll take you and a buddy a couple hours and maybe a few drinks to get the job done.
I'll be installing a Centerforce DF clutch sometime this year. That will be the prefect moment to change out my leaking rear seal.
stangjunkie
381
  • Jan 19, 2006
Ill trade you... you do my heater core and ill swap your rear main!!
its so simple!! all you have to do is go to the parts store and ask them if they have any "Engine honey" tip the bottle upside down and you'll know why its called that.. that should fix it till you feel like pullin the tranny... oh and btw... when you do it go ahead and replace the clutch you wont want to do it it again
5.0 Nostalgia
904
CT
Jan 19, 2006
  • Jan 19, 2006
Wait until you blow the clutch to fix it. A quarter size spot every couple days is nothing. It won't drip on the clutch too much at that rate. If you plan on having a shop do it, definitely don't waste your money. They are going to charge you as much in labor as they would for a clutch. Might as well get it all done at the same time.
SaleenSHO
41
Findlay, OH
Jan 19, 2006
  • Jan 19, 2006
Thanks for the help guys. I think I will wait until i need to replace the clutch and or tranny. The car has 149k on it, so those should be going out sooner or later.
HISSIN50
34
129
Jan 19, 2006
#10
  • Jan 19, 2006
  • #10
I kinda agree with 5.0 Nos on this one. There is a decent chance the new RMS will leak too, so I would not make a special trip in there just to replace it and hope it is a little better. With those miles, your clutch should be ready to come out at some point soon. Then renew the clutch assembly, resurface flywheel, do the RMS, pilot bearing, check the pivot and fork, input bearing retainer, etc (a good once over).
Just MHO. Good luck.
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
