BlownStangGT REPEAT Founding Member Jan 22, 2002 3,860 6 58 43 Lancaster, PA www.cardomain.com Mar 23, 2004 #1 Mar 23, 2004 #1 Stock short block, patriot stage 2 heads, comp cams XE 278H cams, Accufab 75mm Plenum intake with 75mm throttle body, ported lower, 80mm mass air, 24 lbs injectors, Pullies, Hooker Long tubes, 3" X-pipe, 3" Flowmaster cat back ??Thanx
S Solid Snake Banned Nov 26, 2002 940 0 0 GA Mar 23, 2004 #2 Mar 23, 2004 #2 It'll be pretty damn close
dkshadow Banned May 12, 2003 952 0 0 TEXAS Mar 23, 2004 #4 Mar 23, 2004 #4 Solid Snake said: It'll be pretty damn close Click to expand... WTF, who changed yer name?
BlownStangGT REPEAT Founding Member Jan 22, 2002 3,860 6 58 43 Lancaster, PA www.cardomain.com Mar 23, 2004 #5 Mar 23, 2004 #5 yeah I fig it would take a good good tune....is there other parts that would get it over 300 both ways?
BlownStangGT REPEAT Founding Member Jan 22, 2002 3,860 6 58 43 Lancaster, PA www.cardomain.com Mar 24, 2004 #6 Mar 24, 2004 #6 ttt
KJ Hoppus New Member Mar 18, 2003 1,008 0 0 43 Elk Grove CA Mar 24, 2004 #7 Mar 24, 2004 #7 yes or very very close.
G GinoGT Founding Member Aug 11, 2002 1,862 0 36 42 Mar 24, 2004 #8 Mar 24, 2004 #8 You can port the plastic lower intake?
BlownStangGT REPEAT Founding Member Jan 22, 2002 3,860 6 58 43 Lancaster, PA www.cardomain.com Mar 24, 2004 #9 Mar 24, 2004 #9 GinoGT said: You can port the plastic lower intake? Click to expand... I dont know...thats why imasking
stallion98gt New Member May 12, 2003 1,802 0 0 49 Los Angeles, CA Mar 24, 2004 #10 Mar 24, 2004 #10 yeah u should be there..o/r xpipe ?
