Wow I'm a Idiot...Head Gasket!
:rolleyes: Make a long story short. We forgot to put the thread sealer on the head bolts to keep the coolant from leaking. Those are the bolts in the middle of the head. I was wonder if i can possible take them out 1 by 1 and put the thread sealer on? I know there is a both pattern but you guys tell me. SOB grrr lol.... Well on the bright side with the blower the head gaskets aren't leaking anywhere. :rlaugh:
IIRC I think the outer bolts (the ones you can see after valve covers go on) are the ones that intersect the water jacket and require sealer.
You can do them one at a time. I would do them in the opposite pattern that you torqued them down with.
If they are torque to yield type bolts and you obviously are running a power adder, I may buy another set and do it over again with the new ones.
Like I said (in edited post), if it is a torque to yield type bolt and you have a blower, I may just buy new bolts and do them over.
I wouldn't chance reused bolts on a blown application.
You only need sealer on the bolts that intersect the water jacket (lower ones).
Outside (exhaust side) bolts get thread sealer or RTV on the threads.
If TTY, get new bolts preferrably.
I imagine you could take them out one by one, but it is your option. :)
