Write up on the new 2011 5.0 engine
  • Thread starter Thread starter Black95GTS
  • Start date Start date Dec 29, 2009
Black95GTS
1,644
Marlborough, MA
Dec 29, 2009
  • Dec 29, 2009
Deep Dive: Ford's all-new 5.0 V8 — Autoblog
Pretty good read. I love the idea of the new engine, although it doesn't sound too after-market friendly. Hyper-crap pistons and a stock compression ratio of 11:1.
Adam
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Dec 29, 2009
  • Dec 29, 2009
Hypereutectic pistons get an undeserved bad rap. They are actually better on daily driven cars especially ones that Ford has to put a warranty on.
Kurt
Pokageek
2,767
MA, USA
Dec 29, 2009
  • Dec 29, 2009
Kurt
Ok. Why?
Black95GTS
1,644
Marlborough, MA
Dec 30, 2009
  • Dec 30, 2009
All I know is that when I saw a 400+ HP NA engine, my first thought was "Blower! 600 Horse with a bolt on!" then I read it was 11:1. Then my next thought was "Nitrous!" then I read it had hyper pistons.
It ought to be a 12 second ride. I'm just hoping it doesn't weigh 4000 pounds.
Adam
Venom351R
4,548
41
98
MAINE
Dec 30, 2009
  • Dec 30, 2009
Adam
It probably will. Seems like all the auto makers are upping the HP along w/ the weight so you dont really gain any ground at all. IE the 400+ HP charger that runs 13's
rj95svt
422
Hayden, AL
Dec 30, 2009
  • Dec 30, 2009
The engine supposedly only gained 10-20lbs over the 3v which is all in the heads and tivct. The only real weight gain should be that and the weight gained from the 6 speed. I don't think it will be very much.
ProKiller
3,064
15
78
PA
Dec 30, 2009
  • Dec 30, 2009
i want one really really bad now after reading that.
Black95GTS
1,644
Marlborough, MA
Dec 30, 2009
  • Dec 30, 2009
http://blogs.insideline.com/straightline/2011_mustang_ill_ford_fe_9998_3.jpg
This says 3603 pounds curb weight... throw in 50-60 pounds of fluids and you're looking at 3650ish. Not toooo bad considering the competition, but it could easily be 300 pounds lighter IMO. Don't know what wheel/tire package or stereo package this weight reflects.
Adam
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Dec 30, 2009
  • Dec 30, 2009
Pokageek said:
Ok. Why?
Hypereutectic pistons are actually quite strong, but very brittle. They don't expand and contract very much, which makes them ideal for a car with tight tollerances, like this new engine. You could put forged pistons in the car yourself, but you won't be able to get those 10,000 mile oil change intervals, and the engine will wear out faster. It would be worth it if you are really pushing the engine, but not on a stock engine. Hyper pistons are actually lighter than forged pistons too, which give the car a slight power advantage, and better fuel economy. It's a marginal difference, but when you compound that with lower costs as well, it just makes sense to use them.
I would say you could put a 150 shot on that engine with no problem, even with those pistons. I don't see this car getting any heavier than it already is. Remember, the new Camaro has a 415hp engine and is only a tenth faster in the 1/4 as the current 315hp Mustang. So this car ought to be a rocket ship with this engine.
Kurt
Black95GTS
1,644
Marlborough, MA
Dec 31, 2009
#10
  • Dec 31, 2009
  • #10
revhead347 said:
I would say you could put a 150 shot on that engine with no problem, even with those pistons. I don't see this car getting any heavier than it already is. Remember, the new Camaro has a 415hp engine and is only a tenth faster in the 1/4 as the current 315hp Mustang. So this car F'ING BETTER BE a rocket ship with this engine.
Kurt
Fixed it for you.
Adam
Pokageek
2,767
MA, USA
Dec 31, 2009
#11
  • Dec 31, 2009
  • #11
Kurt
Thanks for the education. Good stuff. ..
p.s. In my "dealings" with nitrous which was small and highly controlled, I found a 150 shot to really equal like..110 or so..
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Dec 31, 2009
#12
  • Dec 31, 2009
  • #12
Yeah, should pick up something like that at the rear wheels.
Kurt
blksn955.o
3,263
st.louis mo 314
Jan 1, 2010
#13
  • Jan 1, 2010
  • #13
It depends on what size motor is being used with n2o. Most n2o hp levels are based on a engine volume of a 350/351. More volume....more hp as more n2o to fill that volume. Less volume....less hp will be seen. Also add that many n2o companies rate/get their hp levels at the crank and most real world people see numbers at the wheels/times at the track you will have a loss from the drivetrain.
Hyper pistons are not as forgiving as forged but not garbage either. Just because its forged does not mean its indestructible either.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jan 1, 2010
#14
  • Jan 1, 2010
  • #14
There is one builder named Keith Black who swears by hypereutectic pistons. All of his performance pistons are hypereutectic.
A 150 shot of N2O is whatever jet size that it takes to make 150hp at the crank. If one companies 150 shot makes more power than another's, it's because they are using a bigger jet, and more nitrous. The science is that simple.
Kurt
Dino Dino Bambino
1,673
90
79
Cyprus
Jan 2, 2010
#15
  • Jan 2, 2010
  • #15
If the 3603lb curb weight is correct (31lb more than the 2010 GT), the 412hp 2011 GT should hit the 1/4 mile in about 12.7-12.8, which is a couple of tenths faster than the Camaro SS.
Pokageek
2,767
MA, USA
Jan 3, 2010
#16
  • Jan 3, 2010
  • #16
I have heard of folks drilling out the nitrous nozzles too..hhehe .. an old redneck trick if they want more I guess.
blksn955.o
3,263
st.louis mo 314
Jan 3, 2010
#17
  • Jan 3, 2010
  • #17
Drilling out the nozzle is a good idea if your running larger than a 150 shot in most cases. After talking with a N.O.S. R&D guy, the nozzles in most cases have a hole that is roughly the size of a 150 shot and many companies have std. nozzles like this. This is a large reason why you see people who just do not run that much better with a 175+ jet in place of a 150 jet. There are nozzles out there with larger dia. holes in the nozzles, they tend to be higher price non-std nozzles. These and drilling nozzles is part of how many n2o single nozzle class cars can get 300+ hp out of a single nozzle.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jan 3, 2010
#18
  • Jan 3, 2010
  • #18
There are nozzles available that are so big, it's just not necessary. People used to do that back in the day when bigger nitrous nozzles hadn't been invented yet. I had a few friends that did it.
Kurt
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
A
Help with engine issues/emissions
  • Artyom
  • Apr 11, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 12, 2024
Mindseye007
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
