  • 1994 - 1995 Specific Tech
Wrong distributor?
  • Thread starter Thread starter AnotherRed86GT
  • Start date Start date Feb 29, 2008
A
AnotherRed86GT
  • Feb 29, 2008
I have a stock 95 GT and I recently changed my distributor (squeal of doom, hard warm start). When I had the old distributor out, I noticed that the new one didn't look exactly the same as the old one. I checked part numbers and found out that the new distributor was for a 95 F-150. I put it in anyway and set the timing to 10 degrees btdc. The car starts normally at all times now, but it's definitely down on power now and idles a bit rough. Would the F-150 distributor cause this? (I have a feeling this is a very stupid question, but before I go spending $200, I want to be sure I'm right about this)
Fast63
717
  • Feb 29, 2008
why didn't you just return it right away and get the correct one? my guess is that indeed the wrong distributor is what is causing your problem as the F-150 has a totally different 302 setup.
A
AnotherRed86GT
  • Feb 29, 2008
I appreciate the help, can you tell me exactly what is different about them, or point to some reference that says they're not interchangeable? I just called my local Ford dealer and they said it's fine to interchange them. I can't find any information on the web about this.
GTA_V6_Mustang
1,326
Miami, FL
Feb 29, 2008
  • Feb 29, 2008
Our distributer is only interchangeable with
1991-1993 Thunderbirds
1991-1993 Cougars
And of course
1994-1995 Mustangs
earleys94gt
1,223
Ashley, Ohio
Feb 29, 2008
  • Feb 29, 2008
Also, some auto parts stores have a different distributor listed for the GT's and Cobra's, but they are actually the same.
A
AnotherRed86GT
  • Feb 29, 2008
I actually bought it through MPS Auto Salvage. It has a Ford part number that lists out as being from an F-150. If they DID pull this from a stang, it must have run like total crud. It definitely looks different from my old distributor. I'm just going to buy one from my local dealership and keep this one on my desk as a lesson to NOT try to take the cheap way out anymore.
Thanks for the help guys.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
No spark. 1990 foxbody 5.0 gt
  • Boogi
  • Nov 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
Boogi
Distributor choices
  • Stang9050
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Stang9050
