wrong pcv?
  • Thread starter Thread starter beaver2489
  • Start date Start date Jun 8, 2004
beaver2489
503
st. joseph missouri
Jun 8, 2004
  • Jun 8, 2004
can you install the wrong pcv? or do they all work the same? I bought one from autozone that would fit my gromet and had the hose inlet pointing up so I got it...are pcv's 'universal' for any motor?
drgn5.0
603
  • Jun 8, 2004
you can run any pcv so long as it fits the ford grommet. i run a twin turbo supra pcv valve w/supra grommet inside of a ford grommet. fits real tight and is supposedly better for forced induction cause the valve is smaller.
T
TheUser
1,859
Springfield, MO
Jun 8, 2004
  • Jun 8, 2004
the one from autozone has that plastic thing on there w/ 2 connections..you can actually pull that off and hook your hose directly to the pcv...that's what I did. Replace the screen too if you haven't recently...autozone didn't have it; I got mine at O'Reillys
beaver2489
503
st. joseph missouri
Jun 8, 2004
  • Jun 8, 2004
oh I didn't know that pulled off. I was gonna get a similar license plate made "GT 306" lol. I like how that looks on your missouri plate, so mine should look good =)
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
