ok, well after a close inspection of it in person... I have come to the conclusion, that several people were hella high when they designed the new GT... first, it has absolutely no trunk release inside the car! I looked everywhere! second, the shifter can move almost as much while in gear as it can when in neutral! it's even worse than my stock shifter, from the fox days, even with that 18" long shifter handle they had on it... and last, the windows is seated in the door frame, meaning, if the battery is every unhooked/ect... the window will prevent the door from being opened... along with it's just one more mechanism that could break easily, because it's so frequently used... the window will roll down about half an inch when the door is opened, then re-close when the door is shut...
-oh well... any one got opinions on these things?
