WTF.. Glowing H Pipe!!
jstang209
Jun 3, 2004
640
Stockton 209
I took the car out for a couple of minutes.. came home and looked under the car and my H pipe was glowing.. it looked pretty cool lol.. but seriously it was red!! ive heard that it might have something to do with some vaccumes or sumthing?? i just complete my 5.0 swap and dont have all vaccums connect.. just ones that i new where they went.. here some pics.. there kinda crapy due to my gay sidekick.
86T-Top said:
Could be clogged cats. Are your headers glowing also? If they are you could have a lean condition or the timing could be too far retarded.
Mario
Glowing headers does not mean lean man , do your research your spreading false information ... GLOWING HEADERS = RICH .
10 Engine Wives‘ Tales - Debunked (since i know you wont believe me)
http://racingarticles.com/article_racing-56.html
Thanks, but I'll take first hand experiance b4 I trust something I read on the internet. Read my other reply to you in another headers glowing red thread. Yes they are right that a rich mixture can ALSO cause glowing headers but it is not the only thing. I have seen it first hand that a lean condition will make your headers turn orange.
BTW maybe you should do some more research b4 calling B.S. on someone.
Mario
wat if the headers arent glowing?? just the H pipe.. if the H pipe is glowing the shouldnt the headers too?? i just dont want to go look right now bc its late and my car is too loud.. i do have a leak where the H connects to the headers... prolly on both side.. i dont have the lil donuts installed
Mario
I don't think a lean condition would make your H-pipe glow read. Headers maybe. Even race cars headers glow red when they are running right. It is all about how much heat your letting off. In this kids situation. I believe that it is because he is running too rich or has clogged cats.
Is the line connected from the air pump to the cats? That could be your problem.
SD, and im having trouble with the vac line.. all of them arent connect.. i have a catted H pipe with the gcats removed.. but it still seems to be a lil hotter than supposed to be.. i do have that line connected btw
does is the engine turn rich outta nowhere?? i mean someone would have had to mistakenly advanced the timing too much correct? i took the engine arpart befor i threw it in.. but i didnt mess with the distributer.. but then again i put 15 dollars in my tank and it was already on E in less than 30 minutes...
Test your gas milage that is a good sign if your running rich or not.. my tuned 5.0 can get 32miles per gallon if you baby it (highway).. but still 20+ city if you baby it. A engine can run rich for many reasons.. it could be stuck in open loop one of your exhaust sensors might be bad etc.
is your motor missing...i remember you saying your car was loud and that one guys that worked on it said the cats were clogged...do you have a miss in the motor? if so that puts unburned gas down your exhaust and it burned in your cats...the reason the headers are not glowing is because gravity is gonna pull it down fast and settle in a level area: your h-pipe and on and if you have cats, it WILL burn up in there if anywhere...if not, sounds like your o2 sensors are running in a rich or lean condition...have it scanned...if both of your o2 sensors are bad, check your MAF sensor cause its very uncommon to have both o2 sensors go bad at the same time...then again, i bet it looks like you have ground effects! HA! probably makes the ricers jealous since its "naturally aspirated" ground effects :rlaugh: good luck bro...keep me posted.
-jeremy
jstang209 said:
except for the loud ass leak
Ahhh, I am reminded of the last time I drank water in Mexico........ :spot:
Have you looked for a vac drop off? That can be indicitive of an exhaust restriction.
Good luck.
