hey guys
this is my DD n as some of you may know i swapped my cobra manifold for a ported eddy rpm...so the swap went ok but i needed to set the timing since the dizzee was out
so i go ahead to do so, i set it to 17 as i had it b4 and rev it to 5K n the car just dies. I try it again, no luck. I kept on trying but nothin. So i started turning the dizzee left n right n upside any way i can think of till it fired up again n ran for a min or two with the tach flyin all over the place n it shut off. I tried to start it again, it cranks but doesnt turn. So i pulled the dizzee out n one of the 3 wires inside is shredded, so i reconnected it n try to set the timing again n start it. Same thing, cranks but doesnt turn...but this is where it gets fun! all of a sudden as im tryin to start it i just hear a loud pop n white smoke from the engine bay. The valve cover breathers and the pcv shot about 15 feet away from the car n it was smoking for quite a few minurtes after from the valve covers n pcv hole in the back of the intake.. so i gave up and towed it home.
What could be the damage here?
Possible blown gaskets here or just a dizzee? Im cluless right now...
How do i get it back on the road??
PLEASE HELP I REALLY NEED THE CAR TO RUN, i have no way of getting around
THANK YOU SO MUCH !!!
