car and driver specs for mustang(they are idiots)
http://www.caranddriver.com/article.asp?section_id=19&article_id=7691&page_number=4
Mustang Standing 1/4-mile 14.1–15.5 sec ....... had to be a grandpa driving the car or some retarded kid
2005 FORD MUSTANG
Vehicle type: front-engine, rear-wheel-drive, 4-passenger, 2-door coupe
Estimated base price: $18,000
Major standard accessories: power windows and locks; remote locking; A/C; cruise control; tilting steering wheel; rear defroster
Base sound system: Ford AM/FM radio/CD player, 4 speakers
BASE ENGINE
Type V-6, iron block and aluminum heads
Bore x stroke 3.95 x 3.32 in, 100.4 x 84.4mm
Displacement 245 cu in, 4009cc
Compression ratio 9.7:1
Fuel-delivery system port injection
Valve gear chain-driven single overhead cams, 2 valves per cylinder, hydraulic lifters
Power (SAE net) 202 bhp @ 5250 rpm
Torque (SAE net) 235 lb-ft @ 3500 rpm
Redline 5750 rpm
OPTIONAL ENGINE
Type V-8, aluminum block and heads
Bore x stroke 3.55 x 3.54 in, 90.2 x 90.0mm
Displacement 281 cu in, 4601cc
Compression ratio 9.8:1
Valve gear chain-driven single overhead cams, 3 valves per cylinder, hydraulic lifters, variable intake- and exhaust-valve timing
Power (SAE net) 300 bhp @ 6000 rpm
Torque (SAE net) 315 lb-ft @ 4500 rpm
Redline 6000 rpm
DRIVETRAIN
Transmissions 5-speed manual, 5-speed automatic
Final-drive ratio 3.31:1
DIMENSIONS
Wheelbase 107.1 in
Track, front/rear 62.3–62.8/62.5–63.0 in
Length/width/height 187.6/72.1/54.5 in
Ground clearance 5.7–5.8 in
Curb weight 3300–3500 lb
Weight distribution, F/R 53.0/47.0%
Curb weight per horsepower 11.7–16.3 lb
Fuel capacity 16.0 gal
CHASSIS/BODY
Type unit construction
Body material welded steel stampings
INTERIOR
SAE volume, front seat 53 cu ft
rear seat 33 cu ft
luggage 12 cu ft
Front-seat adjustments fore-and-aft, seatback angle, height (optional); driver only: lumbar support
Restraint systems, front manual 3-point belts, driver and passenger front and side airbags
rear manual 3-point belts
SUSPENSION
Front ind, strut located by a control arm, coil springs, anti-roll bar
Rear rigid axle located by 3 trailing links and a Panhard rod, coil springs, anti-roll bar
STEERING
Type rack-and-pinion with hydraulic power assist
Steering ratio 15.8:1
Turns lock-to-lock 2.8–3.1
Turning circle curb-to-curb 34.4–34.7 ft
BRAKES
Type hydraulic with vacuum power assist and anti-lock control
Front 11.5–12.4 x 1.2-in vented disc
Rear 11.8 x 0.7-in vented disc
WHEELS AND TIRES
Wheel size base, 7.0 x 16 in; GT, 8.0 x 17; opt GT, 9.0 x 18 in
Wheel type cast aluminum
Tires base, BFGoodrich Traction T/A, P215/65TR-16; GT, Pirelli, P235/55WR-17; opt GT, BFGoodrich g-Force T/A KDW2, P255/45ZR-18
C/D-ESTIMATED PERFORMANCE
Zero to 60 mph 5.3–7.5 sec
Top speed (governor limited) 118–150 mph
ESTIMATED FUEL ECONOMY
EPA city driving 18–20 mpg
EPA highway driving 24–29 mpg
2005 FORD MUSTANG
BASE ENGINE
Redline 5750 rpm
OPTIONAL ENGINE
Redline 6000 rpm
DRIVETRAIN
DIMENSIONS
Wheelbase 107.1 in
CHASSIS/BODY
INTERIOR
rear seat 33 cu ft
luggage 12 cu ft
SUSPENSION
STEERING
BRAKES
WHEELS AND TIRES
and that is why I ended my subscription LONG ago.
