Ok. ANOTHER problem. My ride is currently having a problem idling at the right rpm. Allow me to explain. If I even attempt to drive the car without at least a 10 min warmup the idle will drop to 500-300 rpm during a normal stop and during a quick stop it stalls. When the car is fully stopped the rpms will climb back up to around 700rpm. Once the car is warm its pretty steady at 700rpm which is still about 200-300 rpms lower than my previous 2001 GT. I know this isnt normal, but I'm not sure of the cause. My initial thought was vacuum or possibly a brake booster as it only occurs during braking. However, my old 5.0 had a brake booster that was leaking so badly it sounded like an unhappy snake was trapped under the dash and it never had any problem idling or dropping rpms during a stop. So, WTF is it?
! My ride has only 34k on it and the damn thing is a hazard on the rode. If I'm in a panic stop and the car dies I'm screwed! I'm not to interested in replacing the IAC because I know other folks have had no luck with that replacement. If anyone has ANYTHING on this PLEASE lend me a hand.
