WTF stance is TERRIBLE!
ok, well i just converted to a drag setup which consists of the following:
Eibach drag springs (w/ airbag)
southsides
lake wood 50/50 and 70/30
the front swaybar is still in use. but the rear looks so much lower than the fron of the car. granted the front tires are a bit taller (brand new kumho ecstas 711 245/50/16) because the rears are worn almost bald (but still 245/50/16) and i have aluminum heads, AND i have a bunch of crap in the trunk (jack, stands tool etc), the front looks WAY to high in the air. the springs ned to settle correct? do they still settle even though i bought them used? what can i do to either raise the rear or drop the front? thanks alot!
this is the same setup on my neighbors old car ( the springs are off that car) and his car loked sick (stance im reffering to) is it possible his was lower in the front b/c he had iron heads? i knew it would be like this but not this severe... but i dont wanna cut the springs
thanks mav.. heres wat im gunna do. im gunna take all the tools out and see how it looks.. also i recently had the front control arms off.. i might have tightened them down when all the weight of the car wasnt on them somehow, so ill loosen them and retighten.
