  • 1994 - 1995 Specific Tech
wtf?
  • Thread starter Thread starter 302fordracer
  • Start date Start date Jul 19, 2004
302fordracer
738
Vancouver, WA
Jul 19, 2004
  • Jul 19, 2004
ok my car was pinging for like 6 weeks in hot weather only...well after much frustration I found that my MAF wires were dirty so I cleaned them and for two days it ran great even when it got over 90 degrees outside using 87 octane....but today in 83 degree weather it did it again using 92 octane!!!??? any ideas what could be to blame?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 19, 2004
  • Jul 19, 2004
Did you clean your K&N air filter before/after or even at all? Your MAF may be dirty again if you did clean it.
Scott
302fordracer
738
Vancouver, WA
Jul 20, 2004
  • Jul 20, 2004
I cleaned the k&n a few weeks before the problem began or before i noticed it that is....cause it was spring and not hot at that time
HISSIN50
34
129
Jul 20, 2004
  • Jul 20, 2004
i think that is what Scott is getting at - the oil in the gauze can travel upstream and soil the MAF wire. or if you knew that and that was your point with that post, i apologize. it's late and im tired.
i would recheck the MAF again for fun. gauze elements allow bigger microns of dirt through - couple that with a smidge of oil, and your wire is dirty again.
good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 20, 2004
  • Jul 20, 2004
Just had a thought. Maybe the time it didn't ping was a complete fluke? Just a random thought.
It took two good cleanings of my MAF, replacing my ECT/IAT/TPS/fuel filter & 2 treatments of seaform cc cleaner to get my car to stay ping free. It's been good up to 100* heat. I haven't really nailed it yet at 110* + yet. So you may need to replace some of the above parts to stay ping free. In the end, it took another thorough cleaning of the MAF to completely elleviate the pinging, but my guess is one of the above parts was partly to blame also.
The first time I attempted to stop my pinging problem I ONLY cleaned the MAF. It had absolutely no affect. I then replaced the above parts & cleaned my k&n filter. That didn't help. Then I cleaned my MAF again, and voila, no pinging. By re-oiling & cleaning my k&n, a tiny amount of oil may have been present on the MAF wires; Which in the end was resolved by cleaning the MAF again.
And I mean a good cleaning. I sprayed carb cleaner on one side of the q-tip, cleaned the left base post, went to the other side of the q-tip, sprayed carb cleaner on the other side of the q-tip, and cleaned the opposite side of the same left base post.
So at least 1 q-tip for each base post, one for each side of each maf wire. Then a few more to go all around. Make sure there is no cotton fibers left over when you are done.
I think I went through 15 q-tips. I know it may seem a little anal, but in the end it worked and I am ping free, for now.
Scott
302fordracer
738
Vancouver, WA
Jul 20, 2004
  • Jul 20, 2004
ok well the IAT is new and so is the fuel filter just replaced those like a week ago....but I guess I will look at the MAF again and see if it is dirty again....argh pinging is soo frustrating!
302fordracer
738
Vancouver, WA
Jul 20, 2004
  • Jul 20, 2004
Lets says their is a problem with filter getting the maf dirty, or that the problem is due to the maf in some way....if I bought a CAI kit would this deal with this issue?
HISSIN50
34
129
Jul 21, 2004
  • Jul 21, 2004
i believe it is a problem from the oil in the gauze filter. i would surmise that if we could find some guy, somewhere in the world, still running a paper element, he would say he does not clean his MAF as often as the gauze-filter users do. so to answer your question, i think it is a side effect of the K & N (and its oil), not an issue with the MAFS.
good luck.
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
