WTT/WTS 1990 built 306 hatchback
quik660
Mountaineer block pulled @ 60k.(400$)
Keith black dome top hypertethic pistons 10.8.1 Compression (350$)
Summit racing stage 2 connecting rods (400$)
Patriot freedom aluminum heads 185cc 2.02 int / 1.60 exh (1000$)
1.6 Crane gold roller rockers (175$)
Trick flow hardened push rods(100$)
FRPP Roller Lifters
Ford double roller hd timing chain ($125)
Afm-N51HR 226/234 .520/528" 110 lsa (250$)
All ARP hardware (200$)
Proform 7qt oil pan (Double sump) with sensor (200$)
Polished tall Valve covers with 2 breathers ($200)
Cobra upper/lower (365$)
1"ford racing phenolic spacer (75$)
Alum underdrive pulley (80$)
March grooved water pump pulley (110$)
16" Electric fan (150$)
180 stat (20$)
2 row copper radiator (200$)
30 lb injectors (250$)
Proffesional products Adj fuel regulator (25-75) (100$)
190 LPH BBK high flow fuel pump($125)
Water filled fuel pressure guage($50)
High flow BBK fuel rail (220$)
70mm throttle body with EGR block off plate (200$)
75mm calibrated pro-m mass air (220$)
C&L short tube cold air (100$)
UPR 10" cone air filter (50$)
Powermaster 1wire polished alternator($160)
High Flowwater Pump (100$)
Hi tourqe mini starter.(130$)
Battery in trunk/with switch (60$)
Exhaust-
BBK Long Tubes (479$)
2 1/2 BBK h-pipe (189$)
2 40 series Flows with chrome pipes out the back. (379$)
Suspension-
Solid motor mounts (60$)
UPR tub-k member (349$)
UPR A arms (sway bar mounts) (230$)
Strange front 10 way X2 (220$)
Front coil over kit w/170lb spring (220)
Rear lakewood 50/50 drag shocks(120)
Camber/Caster plates billet (150$)
Uni steer manual rack ($300)
uni steer polished shaft ($180)
Bolt on sub frame connectors (125$)
Double hump adj cross member (119)
UPR rear upper control arms (130$)
UPR rear lower control arms (179$)
Trans-
SPEC 2 clutch (300$) NEW.
Alum 150 tooth Flywheel (200$)
Poly trans mount.(50$)
Tri ax shifter with pistol grip (230$)
Zoom adj clutch and quadrant (100$)
IGNITION.
Msd 62al with 2 step ($300)
Custom burnt chip
Dyno Tuned ($600 W/chip) By Tim Matherly @ MV Performance in Statham Ga
Drivetrain-
8.8/ 4.11 motive gear/install kit (300$)
31 spline Moser axles. ($230)
Detriot locker/31 spline (600$)
Hurst Line lock (180$)
FRPP aluminum drive shaft (275$)
2" long wheels studs in rear.
Wheels/tires
15X3 front 15x8 rear draglites (500$)
275-60-15 Mickey Thompson DRs 28" ($400)
Gauges-
Pro comp..water,oil,volt and fuel..Stock tach.
Car has new clear headlights and all weatherstripping..Car body has original paint, which is still fairly shiny and clean, does have a few door dings on the drivers side door,a very straight car for the year.Inside is all original black inteior and in very nice shape with a new black headliner..
Really looking to trade for a more street friendly coupe. Looking for something with A/C and PS
Located in Atl Ga..... Willing to drive some for a good trade/sale
Call/Txt Brad 678-476-5691
Sale price is $7800
