Wut size do I need?
  • Thread starter Thread starter JerryDaugherty
  • Start date Start date Aug 8, 2005
J
JerryDaugherty
309
Near Dallas
Aug 8, 2005
  • Aug 8, 2005
I have Edelbrock Performer RPM heads and Comp Cams Magnum 1.6 RR's My pistons are notched REEEEEEAL deep so PV clearance isnt as major. Wut size psuhrods should I be needing? Oh yea my cam is Crane 2030. Do i need 6.700,6.750,????
J
JerryDaugherty
309
Near Dallas
Aug 8, 2005
  • Aug 8, 2005
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 8, 2005
  • Aug 8, 2005
You need to measure. Usually 6.7" is for TFS headed cars.
txstang84
1,639
42
69
Tuscola, tx
Aug 8, 2005
  • Aug 8, 2005
if you're running Edelbrocks' with the stock style roller setup, then you more than likely need the stock length pushrods (since Edelbrocks utilize stock valve location and angles), 6.272" length, 5/16" diam; that's what we used on 1EVIL88VERT's 302 with Edelbrock RPM heads; FRPP sells a set out of jegs for $40...you'll need hardened pushrods if you're running guideplates
(the non hardened ones will gall themselves to death on the plates)
J
JerryDaugherty
309
Near Dallas
Aug 8, 2005
  • Aug 8, 2005
thanks for the info dude... a question though... will longer or shorter rods dictate higher or smaler lift such as a different ratio rocker arm?
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
87 GT with cam and headers. Do I need an aftermarket manifold and TB
  • Scarlet Fox
  • Nov 12, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2024
65ShelbyClone
