2002BLGT
Well-Known Member
when you get the stock hpipe off , replace the studs in the manifolds with regular studs , the factory ones have a flange on the stud that keeps you from tightening it up really tight , use blue loctite and lock washers with brass nuts . you will be just fine if you do this , otherwise a leak is likely
