  • SN95 4.6L Mustang Tech
X pipe?
  • Thread starter Thread starter stang20_01
  • Start date Start date Apr 22, 2006
1 of 2 Next Last
stang20_01
Myrtle Beach SC
Apr 22, 2006
  • Apr 22, 2006
Im thinking about getting a x pipe are thay all pretty much the same for make power and sound and looking at getting a non-catted pipe.
imblown-ru
247
Roanoke VA
Apr 22, 2006
  • Apr 22, 2006
you'll prbably want a true x pipe. someone will chime in and say which ones those are. i prefer the muscle car sound of the H, so i dont know much about the x
2003stangGT
14
ohio
Apr 22, 2006
  • Apr 22, 2006
magnaflow,upr,slp are some of the true x designs
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Apr 22, 2006
  • Apr 22, 2006
True x pipes are:
Dr Gas. (requires welding)
VRS
Magnaflow
SLP
UPR
Stamped X pipes are:
Bassani
BBK (dont think about this, sounds like poopoo)
D
drunkenfarmer
10
Toronto, Canada
Apr 22, 2006
  • Apr 22, 2006
i had a dr gas, by the way its freekin loud, if u got a popo on ur butt, be sure to shift at 1500 rpm cause anything above that is just stupid loud
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Apr 22, 2006
  • Apr 22, 2006
well i know where you can get a bassani SS for pretty cheap
Black Stang 97
the guy on top of me is funny
Nov 11, 2004
483
Los Angeles, CA
Apr 22, 2006
  • Apr 22, 2006
me too.....it has the removable cats with the o/r legs....came off my 97 GT.....didnt fit the kewbra.....
00FourSixGT
18
  • Apr 22, 2006
the slp x pipe is one of the best IMO, it has the removable cats in case you have to worry about inspection, or if you want a little quieter for a long trip. dr gas x is the best sounding by far IMO as well, not alot of difference considering the design is about the same.
the98stang
2,408
Clovis, CA
Apr 23, 2006
  • Apr 23, 2006
Tru-X pipes will have very little to no horse power gains compared to the regular X pipes. Just stick with what ever you think sounds the best. Don't get a vertain brand pipe because some one told you. Every one likes different exhaust tones. You can listen to some sound clips at www.mustangexhaust.com .
merc123
420
North GA
Apr 23, 2006
#10
  • Apr 23, 2006
  • #10
+1
G
GT02MG
49
MD
Apr 23, 2006
#11
  • Apr 23, 2006
  • #11
I like magnaflow x-pipe.....really nice and easy to install as well.
CanadaStang
2,093
Mb
Apr 23, 2006
#12
  • Apr 23, 2006
  • #12
I'm pretty happy with my SLP. It's stainless [as opposed to aluminumized] and the fit was very good.
StompinR1
17
Chicago
Apr 23, 2006
#13
  • Apr 23, 2006
  • #13
what's the main dif between o/r H and o/r X?
Stang|ess
Oct 18, 2003
941
Hawaii
Apr 23, 2006
#14
  • Apr 23, 2006
  • #14
Stang|ess said:
The main difference is the sound. The xpipe will generally yield a few extra ponies while emitting a "NASCAR" type exhaust note. It's supposed to be more of an exotic sound.
X PIPE ^
H PIPE^
The h pipe will give you a deep muscle car rumble.
Check out www.mustangexhaust.com
Sound is subjective, and no one but you can determine which you like better.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 23, 2006
#15
  • Apr 23, 2006
  • #15
Any one of the major brands would be a good buy. You pretty much just need to decided on the material you want it made of (stainless, or standard) when you buy it. As for the cat less idea.....back when converters were crazy expensive and restrictive, I was all over the idea of getting rid of them. But high flow cats can be had for as little as $55 a piece now and the horsepower loss (about 2hp) over the true O/R set up isn't worth getting the smog police all over your back. Not only that, but it will help keep the cabin area quiet and keep the noise out back, flowing out the tailpipes like it should be.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 24, 2006
#16
  • Apr 24, 2006
  • #16
I noticed that the true-x x-pipes are not as raspy and sound smoother than the stamped x-pipes like Bassani. I've had both and had alot more raspiness with the Bassani....i kinda miss it cuz i think it was a bit louder
Z28 KILR
386
Columbus, OH
Apr 24, 2006
#17
  • Apr 24, 2006
  • #17
I like the SLP design since installation is really easy because of the 3 piece design. Allowing you to change your mind on long tube headers and cats. You can always get the catted setup first and the OR section later if you decide that the catted pipe is not loud enough. I bought the OR first now I have to get the cats since its a little too loud. It's alot more expensive than buying the catted pipe first then the OR section.
evol04gt
29
wadsworth ohio
Apr 24, 2006
#18
  • Apr 24, 2006
  • #18
i have the bbk catless. i hate the loudness and raspiness. having catco high flows installed. catted x's are about 400. catless are 200 plus 100 for cats. ill post the difference tomorrow when i get the cats installed. catless require extensions 30 at summit and mil eliminators 60 at summit. i dont theink you need mil.s with catted pipes so thats 60 buvks you donthave to spend. lol
word.
hognutz
1,940
albany, oregon
Apr 24, 2006
#19
  • Apr 24, 2006
  • #19
main thing on the x-pipe is the location of the crossover and the design of the crosover.
If you look at them you will see there are some differences as to the design.
the BBK and the bassani are a bit different. they are kind of like a champber. the magnaflow is a bit unique as well. It is like two pieced of pipe that cross through each other.
I went with the vrs because it is the cheapest stainles pipe that was just a standard x-pipe design. you have two pieces of bent pipe that are just are opened up and then welded together to create an crosover.
as for who makes more power and all that I don't know the exact answer I just know the dr. gas, slp, VRS are more what I considered to be a normal x-pipe.
CanadaStang
2,093
Mb
Apr 24, 2006
#20
  • Apr 24, 2006
  • #20
I picked up my catted SLP X-pipe from Summit for $399.95
1 of 2 Next Last
I
WTB/Trade 87-95 X-pipe and catbck
  • IconicSilverGT500
  • Apr 23, 2026
  • Exhaust Parts
Exhaust Parts Apr 23, 2026
IconicSilverGT500
I
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
