  • SN95 4.6L Mustang Tech
Yall 96-98s with PI cams, I need help
  • Thread starter Thread starter TNstanggurl
  • Start date Start date Jul 20, 2004
T
TNstanggurl
153
TN
Jul 20, 2004
  • Jul 20, 2004
Just wanted to know if yall had any problems with piston to valve clearance with PI cams? And any other info I might need to know.
T
TNstanggurl
153
TN
Jul 20, 2004
  • Jul 20, 2004
Does anything need to be done to the heads for them to accept the cams? Also do i need to get know cam gears or not?
LI98GTStang
1,715
L.I., NY
Jul 20, 2004
  • Jul 20, 2004
No problems whatsoever getting those puppies in and even uses the stock valve springs. There are easier ways to install them now that the cam tool is out there, so no need to remove the front engine cover anymore. So yes, make sure you get PI cams that accept the bolt-on cam gears as using the cam tool to remove and install will require them. You can move over your stock cam gears, but will need new (smaller) cam bolts to snug them on. This will save you a lot of time. I got '02 PI cams and they are the bolt-on type.
kboy262
437
Atlanta-Kennesaw
Jul 21, 2004
  • Jul 21, 2004
I ended putting Comp Cams in mine for a little extra punch. So far no issues. Installed it with the Anderson Cam Tool in under 2 hrs. Just need a tune now.
cmb91LX
432
Memphis
Jul 21, 2004
  • Jul 21, 2004
Where are you in TN? I may know someone who can help with this process if you are near me.
J
Joel's98GT
368
central OH
Jul 21, 2004
  • Jul 21, 2004
no issues at all, just remember to put the correct cam on it's side of the car and put the spacers on the new cams, If you get aftermarket cams, i would get better valvesprings, but that's JMO
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Q
G
New Owner: Very Clean 1991 GT Convertible. All original with 21k original Miles. How to make it better?
  • gvanginkel403
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
Jarhead67
J
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
