yes, its another cam question: 260AH
I e-mailed comp for a cam recommendation, and he suggested this cam. Since its a "specialty" cam, and not many people know a whole lot about it, I asked him if the XE262H would work well. He said that is probably too big for my appication, although it is borderline. I haven't asked him about the XE256H yet, but I bet it would work pretty good. I'm just trying to get some more information about this cam he keeps suggesting. Can anybody look at the specs and tell me anything about it? I'm not good at just looking at numbers and figuring out the characterists. Anything you know from these specs would help. Thanks
I would run this part #31-412-4, this is one of my specialty cams. It
is kind of a small cam with a tight seperation, which will provide torque and
the sound you are looking for. Here is the spec card for that cam.
Cam Spec Card Inquiry
PART NO. 31-412-4
01 INTAKE MASTER 260H-9
02 EXHAUST MASTER 268H-9
03 ENGINE FS 260AH-8
04 GRIND NUMBER FS 260AH-8
INT EXH
05 HYDRAULIC Y/N YES 14 DUR @.050 212 218
INTAKE EXHAUST 15 LOBE LIFT .2960 .2960
06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO .00 .00
07 MAX GROSS VALVE LIFT .474 .474
08 DUR @ .006 TAPPET LIFT 260 268 17 LOBE SEPARATI 108.0
18 ADVANCE 0
09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS
@ .006 10 INT 22 58
11 EXH 62 26 DATE SETUP / /
12 THESE SPECS ARE FOR CAM(S) INSTALLED
@ 108.0 INTAKE CENTERLINE
