Will 14x8s with 3.5 backspaceing work on the back? I'm wanting to put some cheap wheels on there to get rid of the stockers until I can purchase some goods ones. I'm thinking of these on the back and 14x7s on the front.
I would rather they did not. But I also would like to get as much meat back there as I can. If these won't work any suggestions on some cheap decent looking wheels that will?
If you click the link in my sig you can pull up a wheel chart for you year mustang and look at the various size rims and backspacing required to fit the different sized tires.
outer diamter (15 16 17) x 8 with 4.75 Basckspcing is a popular choice and allows the installation for some beefy tires without much work.
I run 17x8 4.75 bs on my 65 with a 255 tire on later years you can go wider.
Do you know of any cheapy wheels with 4.75 backspacing? The only cheap wheels I can find are 3.5 or so. I plan on spending the dough for the wheels probably like everybody else and get 17 x 8 torque II but right now building up the motor is draining the wallet.
If I get the 14 x 8s with 3.5 how bad will it look on the back and can I get a set of 14 x 7s on the front with 3.5 bs and work with out rubbing on stock suspension?
