Hi all--
Lately, my 66 has been using oil--about a quart every 2000 or so. Before this summer, it was tight except for some minor seeps.
On my way to a show in Biloxi, I had some extended highway time at about 75 mph for almost 2 hours. (The car is mostly an around town machine with occasional pleasure drives in the country.) When I got back from MS, the car was down about 1.5 quarts. I panicked and started keeping records--usually 2-3 times weekly- of my oil levels.
I've noticed that when the car is used around town, the oil use is almost nil. When it is on the highway, even at a steady speed of no more than 70, the oil use goes way up. Case in point. I put about 100 miles on the car today in the country and back on interstate and my oil level was down 1/4 of a quart. That's not good. Yet, at about 100 in town miles, the oil level holds steady or drops just a smidge.
There aren't any leaks that show up in my catch pans under the car or in the same parking place I always park in, so I assume it is using.
Ideas?
What can I do/have done to narrow the problem, short of tearing down the engine (which may have to be done.)
The engine was rebuilt about 19 years ago, but for about 10 of those years, it was an occasional driver. The rest of the time, it is a daily.
What puzzles me is the incresed usage at higher speeds. What could cause that? Cracked ring? Would a compression test show that?
I'm usually clueless, but I'm really stumped now. Can you give me some ideas?
Thanks!
--Paul
PS I'm running Havoline 10/40, if that makes a difference. Oil pressure is good, but drops a tad with the heat and the AC on.
Ideas?
Thanks!
--Paul
Let us know how it comes out. I think a vac gauge is one of THE most important tools on the shelf.
