ZEX 150 shot on stock fuel pump
I'm sure you can get away with it, but I certainly don't recommend it. IMO, you would be playing with fire...better yet, you would be playing with fire while holding a gas can! Lol!
At the minimum, I would recommend getting an SVT Focus fuel pump. You could also probably get away with running a KB BAP with the stock pump.
I've heard hit or miss reviews about the Walboro pump, but all on the internet and not in real life, so you know how that goes.
Does it drop right in as a replacement for a stock GT pump?
The focus pump will basically drop right in. Some people will drill small holes in the bottom/sides of the basket to keep it from getting sucked dry. I didn't do it to mine and have had no problems.
Not sure if the Walbro is plug n play or not.
If you do swap pumps, I recommend you get a fuel tank filler neck grommet at the same time. I ripped mine on the install and didn't catch it til I was driving the car later. Had to drop the tank again to fix that!
