zex dry kit for efi on a carb
Roadblock
208
VA
ok i have the zex dry kit (75, 100, 125) any way this thing uses the tps to activate.......i'm curently thinking of going carbed.........if i go i will use this new carb plate from zex (part #82040) any way is there a way for me to feed the tps voltage (5volts i belive) to the "brick"..... i dont wanna remedy this kit useless with the carb conversion........
i'm perfectly happy having the kit spray at the flip of a switch
disregarding the tps part of the kit, i dont think it would work cause of the whole fuel pressure part of the "brick". that box controls the fuel psi according to the amount of nitrous so i think u would need to use it on efi since carb uses like 0-15 psi, not 0-100 like efi. i dont think u can bypass the vacuum lines either. better to give zex a call....
