i just bought some drilled and slotted rotors they say there zinc plated to prevent rust....does anyone have rotors that are zinc plated and if so does it prevent rust or is it a good idea to paint them with a high heat paint...
Mustang5L5 said:The zinc coating does a decent job preventing rust.
Just a little note however, first time you use the brakes the zinc coating will be swept from the area of the rotor the pad contacts. That means anytime they get wet they will rust up in the spot. However next time you use the brakes the rust will be scraped off again
mansonozz said:5L5 is talking about something like this:
thanks for the info. so what your saying it will not be necessary to paintMustang5L5 said:The zinc coating does a decent job preventing rust.
