Well I spoke to the tuner last night for a while and he gave me some good pointers. He recommended that I go with a PMAS 80mm MAF and a AFM powerpipe. I asked him about the size injectors and he said that 24s are fine for a non-blown application. I trust this guys judgement as he has a wealth of knowledge with regard to mustangs. He also said that in my case with the cobra computer, it pulls timing as I really get on it. So in order to get the most out of my combo he told me to get some dyno time and have chip burned taking care of those computer functions.
The other route he specified was to get a PMS but with that comes more $$$ and still dyno time. He also said that I would need a new fan controller (I forget the actual reasoning). I think it was something like in the cobras the fan is controlled by the computer. The fan comes on at around 205 degrees. That would need to be changed.
I do not know what I should do. I will be getting the MAF and mostly likely the powerpipe but as for the dynoing I am still up in the air. I do not see myself modding this car any more than it is now after I do the MAF. So having said that a chip might be the best choice.
What do you guys think?
What I think is .......... I'd just tune it myself
Here are my thoughts about each issue in the order you listed them
Thats a good meter ... I got no probs with the choice
Believe I could fab up a pipe for a lot less $ than the AFM
I would not sleep good at night with 24's in my Stroker
Now ... Lets talk about that pulling timing subject
True ... you do have a tip in retard
but
The GT pcm retards exactly the same amount
I mean ... its not like it don't advance spark as the rpms climb just because its a Cobra pcm
Actually ... If I was gonna pick from the two pcm's to use without a tune for a h/c/i combo ... I'd run away from the GT to the Cobra as fast as I could
As for the dyno time
Sure, with a tune you'll fix issues with:
load factor
maf/inj's
various other little adjustments for good drivability (closed loop)
spark/fuel tables for max power (open loop)
As for the fan temps
Maybe he is saying ........
the PMS may not have access to that particular pcm parameter
About that last paragraph
If you wanna bypass a lot of dyno time
Thats one of the benefits of Self Tuning
The street is a whole bunch cheaper
Seriously Speaking Though
So many more options become available to you .........
which you have control over I might add
when you Self Tune
As for this guy and your feeling good about him tuning your Stang
If he put your Stang on the rollers, I'd have to think he could burn you a chip to take care of all your concerns
So ... the stuff I said above about the different pcm's would be moot when he does his dyno tuning thing
the 24's however
I'd wanna be hittin em with extra pressure to make them act bigger
Grady
