There's many threads about this in the tuning section. Basically its PMS vs. TwEECer. You'll also need a laptop and a wideband O2 sensor to self tune. And get ready to do some research no matter which method you chose.
I know you respect your tuner, but 24 pound injectors aren't enough for a 331 HCI. 24 pound injectors aren't enough for most 302 HCIs, unless you up the fuel pressure.
Adam
Ole Adam ..................
Hes one of them fellers I almost always can use the little guy
with when he puts up stuff in our forum
Just a small bit to add to his wise words
and
I won't even get into the PMS or Tweecer thing
No matter which device you would choose to Self Tune with ............
Any of them should allow you to optimize your drivability and max power just as efficiently, or at the very least, pretty darn close to the level of a place that uses a dyno to make a chip.
The knowledge of the Tuner is what its all about
Whether he be Self or Pro Tunin
Grady
. He added some AFR185's to it and wanted a tweecer as he noticed it was running out of steam up top from fuel issues and wanted to run 24's. I was talking to him and said AT least 30's if not larger. He got the 30's and after running with the 30's he agrees that 24's would have been WAY too small. He is using my stock gt cam with the AFR's along with the stock gt40 intake so his combo though slightly bigger with a tad (but somewhat close-ish) more head is prob. restricted a good bit as well. He said the truck was just night and day diff. from just the inj. swap and pulled 10x's harder up top.
