I read several FAQs and threads and got a bunch of knowledge. Here's my personal FAQ, as it relates to my 2004 Mustang GT with a fairly stock engine. Please fill in as required.
1. A dry kit sprays N2O before the MAF and relies on the car's EFI system to provide the additional fuel. Depending on the amount of nitrous used, the stock injectors and fuel pump might not be able to provide enough fuel. Hence, dry kits are usually good for 50-125 shots only. True?
2. Anything over a 100 shot in a dry kit will require injector and fuel pump upgrades. True?
3. Anything over a 125 shot in wet or dry will require upgraded pistons and other internals. True?
At this point, I'm leaning towards a dry kit since it has less parts, which means less things to fail (like stuck solenoids), which means a lower risk of kaboom. If #3 above is true then I don't plan on going above a 100 shot so a dry kit makes more sense.
Am I on the right track?
but i would upgrade no matter what
