Water in New Headlight
About a month ago i installed new headlights from 50resto. Two weeks later there was a heavy rain and I had the car out. One of the headlights aquirred some water in it. Is there any way i can drain the water out without pulling the headlights out? Also what if any precautions can I take so I dont have the same problem again? Thanks
You're going to need to remove the headlight to fix the problem anyway.
Pull it out. Drain out the water and allow it to dry thoroughly. Run a thin bead of clear silicone all the way around the edge where the lense meets the body. Allow that to dry. Reinstall.
You're done.
The same thing happen to me couple months back.... it really pissed me off, cuz i had ordered the lights and didnt recieved them for a month and half. but as stated above, use that clear silicone and u are good to go.
Drain and dry headlight, take them out
Buy this
Permatex Clear Flowable Silicone (Any Auto Store)
Squeeze it onto a Q-tip or your finger tip and spread it around the seal where the clear plastic of the headlight meets the back gray plastic of the headlight
Get a good coat on it and go all the way around.
Let it dry and then re-install headlights
(Did this to mine cause I had same problem when I got new lights and even when I spray the lights from every angle when washing the car water doesnt get in.)
You're done.
Where are you guys saying to silicone? Right behind the weatherstripping where it looks like the assembly is pushed together?
