turn signal flasher location
It is behind and above the radio, on the right.
It is unplugged, because I unplugged it to change it. After I unplugged it, I took a picture to share. I replaced with an electronic flasher. It cost more, but is more consistent than the cheap oem flasher.
I wonder if Jrichker has a turn signal relay post that he puts up, or if he has another response where he incorporates TS relay info. :shrug:
If he did, folks that took pictures (you guys did great by doing so!) could send him your pics with a note about what year your car is. After a little while, he'd have a pretty nice list and set of pictures with TS locations by year.
Otherwise, it's a good idea to take two days worth of food and water, a phone and let a loved one know where you'll be in case you don't return (from under the dash :rlaugh: ).
Go to the parts store and get the electronic flasher, usually part number EL-12 IIRC, and your blinkers will flash like they should. You can use the same flasher for the turn signal (the part in the dash) and the flashers(the one on the back of the fuse panel).
I believe the relay was moved behind the radio/glovebox starting in '90 with the intro of the airbag.
I've seen the TS relay in a handful of locations in the aero fox cars - I'm not sure if there was that much thought about where to put it.
