Ordered Bullitt Pedals
Make a day free and grab a 6 pack, no, better make it a 12 pack. They are a pita to install. The brake and clutch pedal are the worst. I soaked mine in scolding hot water to loosen them up and it helped a little. Good luck.
is it really that bad? and do you have any pics of them installed
No, not that bad really. I used the boil, put mostly on then smush it on the rest of the way with the feet. Here's mine installed.
mine came on the car. No benefit at all. In fact, regular pedals actually offer better grip, and who the hell looks under your dash to see what your pedals look like? I can understand why people buy them to put on, but it is hardly worth the effort, IMHO. There is no performance gain, and arguably a performance negative. If you own a Honda, it might make sense, as at that point a performance negative might actually come out increasing performance via the negative times a negative thing.
are you guys serious? a heat gun and 5 minutes and i had them all on. how can i be the only one? the dead pedal and gas pedal are cake, and the brake and clutch you gotta heat for a minute and they slip right on. hook the bottom on first and than slide around the rest
Hahahha.
But mine weren't too bad. Heat em and soap em and it's not bad.
