Max compression on Pump gas?
mike93lx
391
Hudson, MA
I know there are a lot of variables that go into it, but what is, roughly, the maximum compression that is safe to run, at sea level, with 93 octane, on an N/A motor? 10:1, 11:1?
Not looking for precision, just a rough idea.
Thanks!
I have seen cars on the street running 11.5 to 1 compression but i would not go any more then that. The other key to running higher compression on the street is having the car set up properly. Get it tuned and you should have minimal issues with a 11 to 1 compression engine.
I'm used to crappy 91 octane and even worse gas. California isn't the most friendly state for auto enthusiests. However, I don't think that there is much of an advantage running 11:1 vs 10:1 on pump gas. You will not be able to run a lot of timing with the 11:1 motor and you may very well run into detonation problems during the summer no matter where you are. There are other factors too like your cam selection. My point is that if your car is a DD 11:1 will actually make it slower unless you put race fuel in it. In my experience larger motors seem to take to compression and pump gas better. 11:1 in a big block is fine but not a small block. Once again, I have never had anything available to me other than 91 octane or race gas.
11.1 is cutting close on iron heads fine on alum heads, keep in mind camshaft selection plays a big roll in this, little cam= low compression bigger cam= more compression, larger cams bleed off clylinder pressure, also keep combustion chambers small as possible, this eliminates places for detonation to occur. The better the quench are of the head the less chance of detonation.
Like I said, 11:1 here no issues, FULL timing, NO detonation.
