cold air intake fitment
NKau
1,346
Jefferson, WI
Wondering what you guys have had the best luck with. Any problems with any of the cheap e-bay kits? I just need something that will mate to a 75mm MAF and a 65mm TB and not look like poo. I'd reuse the factory setup, but am guessing there's no good way to couple a big MAF to it.
Should note I currently run a C&L inlet pipe with the stock box and Pro-m 75mm bullet and it looks good and works excellent too.
Glad to hear I can keep the stock pieces! I take it I'll need an inlet pipe to get it to mate up to my stock box? Do you by chance have a part number for it? Thanks a bunch DMAN.
To add you may need to knock a little material off the end of the pipe to keep the part off the strut tower (mine was CLOSE but does not touch). The choice to remove the material is just that, a choice, it will fit AS IS with Pro-m and the stock box and stock box/meter coupling.
I don't think I've had to do anything different with either my C&L or Pro-M 77 (maybe 75? don't know for sure) MAF's. They fit the factory tubing on both sides.
