FYI, that HD fork and cable kit are about $48 shipped for the EXACT kit you're buying from ford at buyfordracing.com, so don't pay any more than that at the dealer.
as well, skip the quadrant and fwa and go straight to the fiore fwa and quadrant, best hands down on the market, with the maximum motorsports setup a semi decent follow up (not as fond of their firewall adjuster) read my sig for more info on this subject
skip the alum flywheel and stick with the stock iron, or a steel unit. the alum piece is not as streetable unless you're really making the power to need it, it's really wasted cash on something that will likely effect you in a negative way.
don't forget little stupid stuff like the t5 reverse/neutral safety cable (probably a junkyard item) the clutch cable clip that goes at the fork, NEW flywheel bolts (arp sells a nice set) and NEW metric pressure plate bolt kit, fms sells a nice kit for those, pick them up at your ford dealer.
